The swing arm bolt was very difficult to remove and I had to hammer it and at the same time kept turning the bolt, when it finally came out I noticed the bush in the frame had also moved, looking closely at the gap it appears threaded, I have since tried using grips to screw it back in but no luck yet, I may try a little heat next. Any experience of this?
https://www.dropbox.com/s/in781puqr4dks9n/DSC_0081.jpg
Seen this before?
- malcolmgb
Seen this before?
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Malcolm
Threading that part sounds a bit sophisticated (and unnecessary) for Honda. If you apply steady force you are less likely to distort it than hammering back in. Apply a bit of heat and it should just go back in.
