CL72 Cyl Head Cover
malcolmgb
CL72 Cyl Head Cover
Post by malcolmgb » Fri Jan 31, 2014 6:29 pm
The cylinder head top cover on my 1964 CL72 is solid without a rubber mounting, should it have one or is that CL77 only? Is it a good upgrade if I can find one or just unnecessary.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Re: CL72 Cyl Head Cover
Post by LOUD MOUSE » Fri Jan 31, 2014 6:40 pm
Best I know all CL72 250cc were solid with no neoprene. ......lm
malcolmgb wrote:The cylinder head top cover on my 1964 CL72 is solid without a rubber mounting, should it have one or is that CL77 only? Is it a good upgrade if I can find one or just unnecessary.
malcolmgb
Post by malcolmgb » Sat Feb 01, 2014 5:36 pm
Thanks LOUD MOUSE I have since been told there are 3 types, 1 - M8 bolt ; 1 - M10 bolt ; 1 - Rubber mounted, maybe the 77 vibrated (resonated) more.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Tim Miller
Post by Tim Miller » Sat Feb 01, 2014 7:39 pm
In late 1964 around #4001597 Honda changed to rubber mount on all cl72's. Yes it does help. If your bracket has 10mm hole then yours likley came with solid mount or if it's 8mm then it was rubber mounted.
Tim
Post by LOUD MOUSE » Sat Feb 01, 2014 8:13 pm
Yep.
The parts book shows 2 but not he size
As I recall the sizes you offer are correct. ..........lm
malcolmgb wrote:Thanks LOUD MOUSE I have since been told there are 3 types, 1 - M8 bolt ; 1 - M10 bolt ; 1 - Rubber mounted, maybe the 77 vibrated (resonated) more.
