honda cl77 305 scrambler ignition timing problem
I recently purchased a non running 1966 Honda cl77. It was supposedly rebuilt but had been sitting for some time. It has good compression 150lbs. It will fire on first or second kick but will not run for long or idle. When I checked the static timing i cannot rotate the timing plate counterclockwise enough to line up with the LF or F mark on the stator. Does this mean that the timing sprocket may be off a tooth or two? I am hoping there is a simple fix, but fear that I will need to pull the engine and look at the top end. Any suggestions or advice would be appreciated. Thanks, Tony
- FluteTears
I am not sure that timing is your problem if it starts and then cut out could it be more of a gas problem? A bad timed engine that starts can run just not as good but it will run.
Check your carb if it's been sitting that would be the first place I would look. Providing it ran before siting in the barn.
1974 CT90
1964 CA77
1964 CA77
honda cl77 ignition timing problem
Thanks for the suggestions, but this does not explain why the timing marks "LF" and "F" are so far off from the pointer. The carbs have been cleaned and it does not run very well at all. It is sporadic at best. Thanks for the input. Tony
- jleewebb
points adjustment
try this: adjust the points plate to center of its range first, then set right point gap and proceed per Ed's tuning recipe here: http://www.honda305.com/cb77_700/cb77-716.htm
I think that's how I handled the problem, been a while, good luck... --Lee
'62 CB77. "It's a rider."
Davo and Lee, Thanks for the suggestions. With rotor on F the line on the cam lines up at 9:00 or 3:00. With the rotor on LF the line on the cam lines up at 12:00 or 6:00. I suspect that something must be off in the alignment of the cam sprocket. I am surprised that it fires at all and that the piston is not hitting the valves. I was hoping against hope that I would not have to pull the engine. Thanks, Tony
