CL77 - trying to ride / how do I adjust the idle?
percepto99
Post by percepto99 » Thu Aug 28, 2008 1:25 am
sorry if this is a lame question - but do I adjust the idle with the two screws on sides the carbs? When I can get my bike started, I can't keep it running without constant feathering of the throttle. At the same time it backfires. If I leave it alone it dies out and then doesn't want to kick over again. Thanks for your assistance
kustommusic
Post by kustommusic » Thu Aug 28, 2008 2:08 pm
99, As you see you have ywo idle screws per carb. The screw that goes straight in goes to the bottom of the slide to raise and lower for idle speed. The other screw,that angles in, is your mixture screw. Inital adjustment forthat is 1 1/8 turn out. If you have to change the mixture screw setting from the 1 1/8 turn a whole bunch then you have other problems too. You should start by getting a shop manual and reading up on repairs and adjustments. Good Luck, Kustommusic
cbxmountainman
CL77 Carbs
Post by cbxmountainman » Thu Aug 28, 2008 9:12 pm
As mentioned, best thing is a manual that tells how to do all this.
rebelbob
Post by rebelbob » Wed Sep 03, 2008 6:43 pm
Where can I obtain a manual?
1967 CL77
Post by LOUD MOUSE » Wed Sep 03, 2008 7:17 pm
They are many offered on eBay at this time. .............lm
rebelbob wrote:Where can I obtain a manual?
1967 CL77
RIDE IT DON'T HIDE IT!
kustommusic
Post by kustommusic » Thu Sep 04, 2008 6:32 pm
You can also find them at Amazon.com Kustommusic
