CL 72/77 front fender
OldScrambler
Blade & Brace
Post by OldScrambler » Tue Jan 17, 2017 12:44 pm
The 6-hole is the same profile as the 8-hole and the original 6 holes are in alignment to the 8-hole brace.........so just add two new holes in the blade.
That ebay bobbed item will not fit on the steel fork legs.
I will check my spares. I may have a spare steel blade and a complete brace..........may need minor work on the blade plus paint. Always tweak the brace on the forks to fit the blade...........
I'll let you know later today..................If you send an email I can return pics. Dennis in Wisconsin
thepunisher2007
Post by thepunisher2007 » Sat Jan 21, 2017 6:41 am
So are we saying that there are 2 diferent bracket types in relation to the mouning onthe forks? as I never see them labled as early or late in listings as you find with many other parts
Glenn-N
Post by Glenn-N » Sat Jan 21, 2017 7:08 am
Yes, early style forks (small brake hub) have the 8-hole fender + bracket
Later style forks (big hub) have the 6-hole fender + bracket
The mounting points on the forks are different so afaik they are not interchangeable.
