Item number: 140443840710
Post by LOUD MOUSE » Mon Aug 23, 2010 7:38 am
My message to him under his reply. ........lm
Hello:
My mistake, it is a cl77 305. Best Regards, Suburbanstuff
- suburbanstuff
Click "respond" to reply through Messages, or go to your email to reply
Respond
To: suburbanstuff
Subject: emo2 has sent a question about item #140443840710, ending on Sep-01-10 12:04:59 PDT - Honda : CL
Sent Date: Aug-22-10 16:08:08 PDT
Dear suburbanstuff,
This bike is far from original. This frame is a 1966 frame as are the buddy pegs.
The front fender is After Market not HONDA. Wrong speedo housing, wrong headlight housing, wrong horn, wrong rear sprocket, wrong mirrors, kick lever is far from correct location, both tires are wrong size, Blue paint isn't the original paint as the year this bike was issued that color wasn't used yet. (check fuel valve) Tail light is for a 1967 not this frame. Wrong cover on tool box. This one is from a CB160. Rider pegs are from bikes made after 1033482.
Turn signals are After Market as this bike wasn't issued with them. Tank badges are HONDA but made after the CL77 series was over.
- emo2
rustywrench wrote:Not to mention the tool box and what is with that kick start lever? Also the drive sprocket looks to be a bit small for stock/original not that longer legs are bad but not stock. I'm not sure what a 101 series vin would be year wise but a long way from 68 for sure. my 2cents,,,,,,,,,,,,Rw
Post by davomoto » Mon Aug 23, 2010 8:14 pm
Brake pedal is early, grips are A M , wrong rear heat shield. Basically a collection of parts assembled with no regard for proper year / model.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
mooney1el
Post by mooney1el » Mon Aug 23, 2010 8:56 pm
Why do you say the brake pedal is early? To the untrained eye (mine) it appears the same as my '67 which is most definately original.
Richard
mooney1el
Post by mooney1el » Mon Aug 23, 2010 8:57 pm
Richard
Post by davomoto » Tue Aug 24, 2010 8:03 am
The part that your foot pushes down is flat. On the later bikes it has an apron around the bottom of it. I can post a pic of the difference later today.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
mooney1el
Post by mooney1el » Tue Aug 24, 2010 8:43 am
Ah Ha! Now I see the difference. Thanks for the explaination!
Richard
