Post
by LOUD MOUSE » Sun May 02, 2010 7:45 pm
Please give a pic of the area where the carb mounts to the head.
I'd like to see that area. ......lm
TrickleDown wrote:Thanks much for the info. I'm pretty sure this bike was hastily put together for the auction back in the 90's when parts were a little more available.
Here's another oddity. Check out how the tank was cut to accept the carbs. What's strange here? Doesn't look at all like my old CL72.
Thanks
TrickleDown
Post
by TrickleDown » Mon May 03, 2010 10:25 am
Thanks for the response loud mouse. I've posted some good photos here:
http://dashplaque.net/CL77
I just don't understand the reason that the tank brackets were cut for the carbs to fit. I have another set of carbs and they look the same.
BTW the fender is certainly an 8 holer.
Thanks
Stuart
Post
by LOUD MOUSE » Mon May 03, 2010 10:28 am
TrickleDown wrote:Thanks for the response loud mouse. I've posted some good photos here:
Thanks
Stuart
TrickleDown
Post
by TrickleDown » Mon May 03, 2010 11:36 am
More photos of where the carbs bolt to the head are here:
Click on any of the photos to enlarge. Click the arrows on the upper left of the page to go to the next photo.
Thanks
Post
by LOUD MOUSE » Mon May 03, 2010 2:58 pm
The carb isn't the problem.
I suspect the area of the rear tank mount.
The frame has a large hole which HONDA installed rubbers on each side which determines the height
of the tank mounting bolt.
I suspect the centering rubbers are not there and the bolt is laying at the bottom of the frame mount. ............lm
TrickleDown wrote:More photos of where the carbs bolt to the head are here:
Thanks
TrickleDown
Post
by TrickleDown » Mon May 03, 2010 3:08 pm
Just checked the bushings. They're there and look almost new. When the tank bolt is loosened there is no play in the bushing. The tank appears to be in the only position in can be in....
I'm going to remove the tank next weekend as it has a small bit of rust inside. I'll be able to get more photos then.
Thanks, Stu
Post
by LOUD MOUSE » Mon May 03, 2010 3:11 pm
Please pull the tank and send pic when ya can. ......lm
TrickleDown wrote:Just checked the bushings. They're there and look almost new. When the tank bolt is loosened there is no play in the bushing. The tank appears to be in the only position in can be in....
Thanks, Stu
