M4x0.75 x 16mm Flat head Screws
chance
Post by chance » Fri May 11, 2018 10:38 am
Does anybody have a source for M4x0.75mm flat head screws? I have an ignition switch that is drilled for the old 0.75mm pitch screws. I need a couple. Thanks in advance.
Frank in Wyoming
Post by Frank in Wyoming » Tue Aug 14, 2018 8:05 pm
You might try monsterbolts.com
chance
Post by chance » Tue Aug 14, 2018 9:26 pm
Thanks, but I’m looking for the old JIS .75 thread pitch. The CL parts guide incorrectly identifies this as an M6 but everyone I’ve checked have M4’s. Anybody got an old CL switch sitting around with hardware?
Re: M4x0.75 x 16mm Flat head Screws
Post by LOUD MOUSE » Thu Aug 16, 2018 5:29 am
I had enough problem locating those JIS screws so I just bought a ISO tap and a few screws and solved the problem. ...............lm
chance wrote:Does anybody have a source for M4x0.75mm flat head screws? I have an ignition switch that is drilled for the old 0.75mm pitch screws. I need a couple. Thanks in advance.
chance
Post by chance » Thu Aug 16, 2018 10:36 am
Thanks, Ed. Did you retap at M4x.70 thread or did you go with a M5 or M6?
Post by LOUD MOUSE » Thu Aug 16, 2018 10:42 am
I stayed with the 4 and got the ISO,(used today) thread. ........................lm
chance wrote:Thanks, Ed. Did you retap at M4x.70 thread or did you go with a M5 or M6?
