Figured out my kick start issue
listen2this1
Post by listen2this1 » Thu May 31, 2018 11:18 pm
I knew going into this build that the kick start wasn't working. Since it hasn't run in 35 years I figured the spring in the ratchet system was bad. I was wrong. I'm guessing the bearing went bad and caused the shaft to seize. It got hot enough the gears on the shaft are seized. Now the hunt for a transmission.
Image20180531_214810 by listen2this1, on Flickr
Image20180531_215813 by listen2this1, on Flickr
Image20180531_222054 by listen2this1, on Flickr
Re: Figured out my kick start issue
Post by G-Man » Fri Jun 01, 2018 1:46 am
Yep - you definitely need a new gearset!
Check out all of the oilways and the filter before you reassemble.
Did it have enough oil in it?
Can you tell if there was a full set of rollers?
How about the crankshaft?
listen2this1 wrote:I knew going into this build that I kick start wasn't working. Since it hasn't run in 35 years I figured the spring in the ratchet system was bad. I was wrong. I'm guessing the bearing went bad and caused the shaft to seize. It got hot enough the gears on the shaft are seized. Now the hunt for a transmission.
AlanW
Post by AlanW » Fri Jun 01, 2018 3:27 am
Saw exactly the same on my elder brothers cb72 in 1966, it was 1 year old and well maintained. Fortunately we now know that if the kick start moves forward when the engine is running it's a sign that the shaft and bearings are probably starting to wear and need attention.
As G said, make sure there's no debris in the oilways and the crank.
Good luck with it.
Al.
listen2this1
Post by listen2this1 » Fri Jun 01, 2018 8:51 am
Not sure about the oil. It had a good amount in it when I drained it but that was from 35 years ago. I had another set of eyes look over it and everything else appears to look good and have all the correct pieces. We did find a couple pieces or metal in the pan. Going to look over again tonight.
Any tricks or tips on how to clear the oilways?
Post by G-Man » Fri Jun 01, 2018 12:56 pm
I use pipe cleaners (soaked in solvent) and teapot brushes, but I am English. :-)
https://www.ebay.co.uk/itm/Mini-Bristle ... Sw8HBZGV8G
https://www.ebay.co.uk/itm/White-Flexib ... SwOy1aqPxl
listen2this1 wrote:Not sure about the oil. It had a good amount in it when I drained it but that was from 35 years ago. I had another set of eyes look over it and everything else appears to look good and have all the correct pieces. We did find a couple pieces or metal in the pan. Going to look over again tonight.
