Post
								by DJM » Sun Feb 04, 2018 6:56 pm
			From memory there are five 10mm bolts in this area. four of them 10 x 48, the main engine mounting bolts and the long one that goes right through the frame and oil pump casting.
I think the bolt you refer to is wrongly annotated and is probabaly supposed to be one of the four footrest bracket fixing bolts.  These are also shown on page 46 under F8. These are all 8mm bolts three shown as M8 x 16mm the other M8 x 25.  I think the later M8 x 25) is also an error as 25mm would be too long in this location, probably 20mm would be right or even 18mm, you need to try some for length to check.
Coming back to your original question #22 M10 x 36 has washer shown with it #28 listed as WP8 or 8mm so the bolt can't be an M10.
