Post
by G-Man » Wed Mar 23, 2016 1:00 am
Phil
Thanks! Saves me trying to measure up. I think I might buy a few 'just in case'
PhilD wrote:Hi all,
In answer to G-man's comment Dave Silver has the swing arm shock bushes listed as part no. 40548_268_000 for both the CB77 and CB400F. My understanding is that these bushes were common to a number of different models. I have had sets of these from Dave and can confirm that they fit the CB77 swing arm and OEM rear shock units.
PhilD
HondaPaul
Post
by HondaPaul » Sun Mar 27, 2016 9:23 am
I got the CB72 shock bushings from DSS yesterday. Not even close. They are
2mm larger on both the ID and OD. No help here.
Paul
G-Man wrote:It would be interesting to see what the difference in size is from the CB72 part which was used in the CB400F. If it's only the hole in the middle that could be easily fixed.
http://www.davidsilverspares.co.uk/part ... 548268000/
I might buy a couple just to check.
HondaPaul wrote:Thanks for the help everyone. After talking with Ed on the phone, I think I have a plan and that is to leave the steel bushing in and mask them. As far as the shock bushings go, I will buy a replacement from Ed. I am glad he has one, cuz apparently nobody else does. So, thanks Ed!
Paul
Post
by G-Man » Sun Mar 27, 2016 10:05 am
Bad luck there. I assume they are OK for CB72 as they have a CB72 number.
For those of us with the tools - it might be possible to fix that......
HondaPaul wrote:I got the CB72 shock bushings from DSS yesterday. Not even close. They are
Paul
Paul
Post
by LOUD MOUSE » Sun Mar 27, 2016 10:49 am
I have 2 and sent you a PM. ........lm
Paul
Paul
jsmith1107
Post
by jsmith1107 » Mon Mar 28, 2016 9:03 am
I never had any luck with DSS. I ordered a couple of what I thought were nice looking cables from him when I was restoring mine and they were not the correct ones. I try and stay away from his stuff.
1974 Yamaha DT125 Enduro
1974 Harley Davidson AMF X90
1976-7 Yamaha XS 650
2-1966 Honda Scrambler
1973 Suzuki T500 Titan
Post
by G-Man » Mon Mar 28, 2016 10:58 am
I've had tons of good parts from David Silver. The big problem with buying up dealers' old stock is that you are relying on them to keep things in the correct marked bags / boxes for 40 years or more.
I suspect a lot of the leftover parts are 'returns' which got put back in the wrong packaging.
In the case of the shock busings - they were CB72 / CB400F parts so may or may not have worked on the Scrambler.
If there is uncertainty I get them to send a photo.
jsmith1107 wrote:I never had any luck with DSS. I ordered a couple of what I thought were nice looking cables from him when I was restoring mine and they were not the correct ones. I try and stay away from his stuff.
jsmith1107
Post
by jsmith1107 » Mon Mar 28, 2016 11:17 am
I am not trying to bash his company--just saying MY experience with him has not been good in the past and because of it, I won't go back.
