What year(s) is this Scrambler
Post by LOUD MOUSE » Mon Jul 06, 2015 7:21 am
The red frame shows it is. ..............lm
malcolmgb wrote:Is the frame a late model with brake cable bracket welded on?
chance
Post by chance » Mon Jul 06, 2015 10:40 am
Now I'm really confused. The frame has the early style front seat mount. Which does not look like it was added later. Also the brake cable bracket appears to be factory welded also. I just assumed that this was an early, small brake bike that had some parts swapped out later like so many others. Since the frame number is so close to the transitional number it may have a mix of parts from the factory. Then again it may have been built from several parts bikes. Thanks for all of the input. I'll post some pictures of the build up as it goes.
Post by LOUD MOUSE » Mon Jul 06, 2015 11:55 am
The seat was changed at CL77-1033XXXX. ..................lm
chance wrote:Now I'm really confused. The frame has the early style front seat mount. Which does not look like it was added later. Also the brake cable bracket appears to be factory welded also. I just assumed that this was an early, small brake bike that had some parts swapped out later like so many others. Since the frame number is so close to the transitional number it may have a mix of parts from the factory. Then again it may have been built from several parts bikes. Thanks for all of the input. I'll post some pictures of the build up as it goes.
OldScrambler
Post by OldScrambler » Wed Jul 08, 2015 5:56 pm
'built from several parts bikes' .................I think we all agree!
As you build it...........I would try to be true to the big-brake models.............
