Main Centre Stand Spring Hook
Ian_C
Post by Ian_C » Thu Aug 29, 2013 11:24 am
I am trying to fit a centre stand to a CL77 and I find that I need a horseshoe shaped part that connects to the upper end of the spring - I am not sure exactly how the horseshoe is held to the main frame. I need to make this horseshoe part so could somebody sketch it for me with basic dimensions. The part is shown on the parts catalogue as item 50523-273-010.
Many thanks for your help, Ian
ggray
Post by ggray » Mon Sep 30, 2013 10:07 am
I'll take a photo of mine and post it.
Gary
'65 CL77 Owner
Ian_C
Post by Ian_C » Mon Sep 30, 2013 1:50 pm
Many thanks Gary, your help is much appreciated.
Ian
ggray
main stand spring hook
Post by ggray » Mon Sep 30, 2013 6:42 pm
Ian,
The 50523-273-010, MAIN STAND SPRING HOOK upper end mounts to a "BOSS" that is welded to the inside of the LH rear frame tube.
It is immediately inboard of the rear brake switch mounting location.
The hook wraps around the center stand and the return spring attaches to the lower end of the hook.
I have attached a photo (sorry about the focus) of the hook attached to the frame of my 1965 CL77.
As for making one, Ohio Cycle, www.ohiocycle.com lists them in their aftermarket section for US $7.50.
Let me know if you need any other info.
Hope this helps,
Gary
MAIN STAND SPRING HOOK.JPG (90.88 KiB) Viewed 3834 times
'65 CL77 Owner
Ian_C
Post by Ian_C » Tue Oct 01, 2013 2:22 am
Many thanks Gary for the photo and info on Ohio Cycle - much appreciated, Ian
ggray
Center stand spring hook
Post by ggray » Tue Oct 01, 2013 8:22 am
You're most welcome Ian.
Send us some photos of your bike.
Gary
'65 CL77 Owner
