Removal of "plastic pads" on gas tank
rattler
Post by rattler » Fri Mar 23, 2012 9:47 am
Is there a preferred way of removing the pads from the gas tank? How are they attached? I don't want to damage anything in the removal process. At times I can be good at that!!
linmictil2
tank pads
Post by linmictil2 » Fri Mar 23, 2012 11:33 am
Morning: I just put the old EOM set back on a CL77 tank I painted. As long as the rubber isn't "hard" you can just pull it right off. There is a lip on the tank behind the pad. Grab the very back of the pad and pull out and up. The rest just pops off with a little pulling. It is a little harder getting it back on than off. I hope I explained this so you understand.. Let us know if this helps or not.
Mike
66 CL77
CL100
2 -CB125s
ATC200
rattler
Post by rattler » Mon Mar 26, 2012 11:55 am
Thanks for your reply, Mike. I will have at it. I'm wondering if it would help to apply some heat for reinstallation?? First I have to get it off in good shape! Your instructions were fine
Paul Strassmaier
Post by Paul Strassmaier » Mon Mar 26, 2012 8:40 pm
Definately warm them up, and the generally come off easiest in the lower back corner first, just pull them back toward the seat before you pull out! Good luck, Paul
rattler
Post by rattler » Wed Mar 28, 2012 9:22 am
More good info. Thanks Paul. I am completing a 2 year restoration on a 66 Scrambler, and delayed the tank painting to the last. I need to get going on this. Thanks again
