hi everyone, any thought welcome. in the process of restoring a cl72,the engine is out, seized pistons & barrells removed, oil pump out,clutch basket & primary chain removed. i havn,t split the cases yet.
The question is after restoring quite a few difrent bikes the gearbox does not rotate backwards i have never really noticed on previous jobs, it feels like a sprag clutch, it makes no diffrence if it,s in a gear or neutral, the kickstart shaft rotates ok & drives the mainshaft. can this be normal? i think not,but everything looks ok,i can see into the box & gears loo ok, it means if in gear with the cluth pulled in you couldn,t move the bike backwards!!
gearbox strip
