restoring a 66 CL77 and need to dis-assemble the rear shocks to chrome and
paint. Not sure on the correct steps. The seals on top look to come out but
they do not pull out with light prying. any experince or advice ?
1966 CL77 rear shock disassembly
I put a long bolt through the top eye, hook a tie down hook to each side of bolt, hook tie down to ceiling hook. Then pull down on upper cover, and have an assistant remove the two collars. Release the top cover, and shocks will come apart for re-painting and plating. Hope this makes sense.
Cl77 Schocks
I just did my cb77 shocks with this
http://www.bikebandit.com/product/13181 ... =338726025
Progressive shock spring compressor best $45.00 dollars I have ever spent should work on cl77 shocks.
Everyone chime in would like to make sure this would work for a scrambler.
Thanks,
Kirk
Thanks,
Kirk
2-1966 CB77 Projects
1965 CB77 Partsbike
1967 scrambler pile of parts
1972 Cb350
1965 CB77 Partsbike
1972 Cb350
