excessive oil no top pistons
albert winslade
Post by albert winslade » Sun May 22, 2016 12:59 pm
new piston rings fitted bores deglazed valve guides good. plugs oil up oil coming out of exhaust port on tacho side of engine. Thank you if some one can help me Albert.
Post by G-Man » Mon May 23, 2016 2:03 pm
Did you fit the o-rings on the front two corner studs between head and barrel?
