Is a battery necessary for proper running....?
Crispy1
Post by Crispy1 » Wed Sep 24, 2014 10:14 am
'64 CB77 Superhawk w/ 15k. I've read a couple posts in the archives that seem to suggest the battery contributes to the ignition working. I thought it was a conventional magneto. Thanks, C.
OldStan
Post by OldStan » Wed Sep 24, 2014 10:35 am
Alternator, not magneto. Battery is necessary with the stock setup.
63 CA78
Crispy1
Post by Crispy1 » Wed Sep 24, 2014 10:50 am
Thanks Stan, I just found some other threads on the subject; most talking about weak charging. When I got this bike, I assumed (first mistake) it was a mag and proceeded with my work. When the bike started and idled, I never gave it a thought. If you saw my other posts, it would only run 3-4 minutes and not much off-idle.
Question- Have I done damage running without a battery? I did have the (+) battery cable wrapped in black tape. C.
Crispy1
Post by Crispy1 » Sat Sep 27, 2014 1:34 pm
The answer is YES!!!
All it wanted was a battery! I put a battery in and it runs like a champ. I still have a right side carb slide that doesn't want to go down to idle. I can reach in and push it down but it wants to creep back up.
Very fun day hitting the back roads by my house on the first real test ride.
Post by G-Man » Sat Sep 27, 2014 1:46 pm
Nice!
