Need turn signals to pass inspection
GG
Post by GG » Tue Oct 26, 2010 2:33 pm
So, Costa Rica has no 'grandfather' clauses for old bikes. Everything street legal must have blinkers. I'm probably going to adapt some blinkers I can find here in the country - my question is this. Can I just use a regular 12v flasher to run the blinkers? Thanks!
rustywrench
winkers
Post by rustywrench » Tue Oct 26, 2010 3:02 pm
Having just gone through this on my cl, I can tell you not to use an older type mechanical flasher can as they do not respond well to the erratic voltage spikes of these electrical systems. I used an electronic solid state flasher with three posts. One +, one neg or ground and one to the switch. You should be able to find one at any decent auto supply store. Good luck,,,,RW
GG
Thanks for the tip on a flasher
Post by GG » Tue Oct 26, 2010 3:10 pm
Thanks Rustywrench! I'll make sure it's electronic. I don't think it will be hard to find.
