CP77 Production Date?
Hello
A Newbie here. I've just realized the bike I purchased was a CP77 and not a CB. Going off of Bill Silver's book I believe the bike is a 1965 since the number is earlier on in the sequence. My serial numbers are:
CP77E 1000071
CP77 1000062
I am a little unsure though. I have the camshaft apart and have measured the spline which is 19mm which is the newer size. The date on the parts change bulletin in Silver's manual (pg63) is dated Aug of 1967. Does this mean that this engine is a '67? From what I can find in the forum there is a lot of consensus that the CP and CB engines are the same. Am I correct?
Thanks for any help?
Trevor
CP77E 1000071
CP77 1000062
Trevor
It's the 7 number format and these were used from 65-67 per the Bill Silver's book, but he doesn't mention the CP. I would think the CP series used it's own number sequence, so finding the exact year may be a challenge. Did you look at the tag on the wiring harness under the tank? This will have a year and may give you a clue to the year it was made.
Gunner
Gunner
Dating Using Wiring Harness
I checked out the wiring harness. I don't know if it's original or not. But I need some help deciphering it. The tag is white and some numbers/letters are hard to read. There's three lines as follows:
B7248FD
? 9 ?
SU??TOM0
The question marks are letters/numbers that I can't read. I think the bottom line is actually:
SU14TOMO
CAn anyone date this bike with this info. Is this a factory harness?
Thanks for the help.
Trevor
B7248FD
? 9 ?
SU??TOM0
SU14TOMO
Trevor
Re: Dating Using Wiring Harness
?9? has one missing and the first was a 1 so you know the first two are 19??. ......lm
youngjames wrote:I checked out the wiring harness. I don't know if it's original or not. But I need some help deciphering it. The tag is white and some numbers/letters are hard to read. There's three lines as follows:
B7248FD
? 9 ?
SU??TOM0
SU14TOMO
Trevor
RIDE IT DON'T HIDE IT!
LM,
Thanks. I'm really enjoying the site and probably have spent about 20hrs in the last few days reading old posts, getting ideas. I've been inspired. I found an old post with a picture of a readable wiring harness. I can barely make out the last digit on mine. I believe it's a "7". I can just see part of an angled line. So, based on this and the fact that I have the smaller cam spline, I think I have a 1967 CP77.
I'm hoping to start posting my restore in the next week or so. Reading everyone else's posts has been interesting and enjoyable. I figure that since I don't know what I'm doing for the most part, if I'm uploading pictures someone will take pity on me and tell me what I'm doing wrong.....:)
Trevor
Trevor
