So I got stranded today...for about 20 minutes
GarageRacer
Post by GarageRacer » Sun Oct 30, 2011 12:26 pm
If I get a better rectifier, would that allow me to run the headlight without worrying about my cruising rpm?
Post by LOUD MOUSE » Sun Oct 30, 2011 2:21 pm
I rode these bikes in the early 60's and NEVER blew a bulb other than when I missed 2nd gear getting on the freeway and OVER REVVED the engine TERRIBLY. (several beers at 2:30 AM)
So we don't know the voltage when ya blew the bulb.
It's been known since the early 60's that ya need to have the battery at 12 volts or ya will blow bulbs.
From what I can tell ya first clue was it wouldn't start with the starter so ya kicked it.
Tis possible the full wave rectifier (radio shack) could keep the bulbs from blowing when the battery is low but who's to know.
Tis a shame ya charged the battery after the fact.
Sort of like ya can change parts but ya still need a 12 volt charge to ride these bikes. ...............lm
GarageRacer wrote:It's sitting right at 12 volts. Although I stuck it on the battery charger as soon as I got home and it's now fully charged.
GarageRacer
Post by GarageRacer » Sun Oct 30, 2011 2:39 pm
All the electrics still work and the headlight works also. I just opted not to have it on when I rode it back.
Post by LOUD MOUSE » Sun Oct 30, 2011 2:42 pm
I assumed ya blew it.
If it's good then be sure to keep the battery up and ya can ride at speed if ya like. ......lm
GarageRacer wrote:All the electrics still work and the headlight works also. I just opted not to have it on when I rode it back.
GarageRacer
Post by GarageRacer » Sun Oct 30, 2011 2:48 pm
Would it still be a good idea to get a better rectifier? Or are the stock ones pretty reliable?? I checked the charging system and it's charging just fine. So I know it's still good.
Jethro
Post by Jethro » Sun Oct 30, 2011 5:02 pm
The old selenium rectifiers work but the full wave radio shack ones work much better. I put one on my Dream and it keeps the battery charged really well. It turns the starter over very strong and I have not charged that battery for six months. They are only $3.50 and require very little wiring. Super easy. I highly recomend it.
Post by davomoto » Mon Oct 31, 2011 9:02 am
My bikes tend to sit for weeks between rides, so here's what I do. I turn the headlight switch on the bucket to on position. I then put the handlebar switch in the middle position, so the headlight is off, but the extra charging coil is enlisted to bring the battery up. I have not blown any bulbs doing this. Not all bar switches have that option, and you have to finesse it into the middle position. I always upgrade the rectifier to a modern solid state unit.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
