PDO::ERRMODE_EXCEPTION, PDO::MYSQL_ATTR_INIT_COMMAND => "SET NAMES utf8mb4", ] ); // newest completed CA entry (via view) $sql = " SELECT model_year, model, ADM_StateOrProvince, ADM_Country, condition_value, opinion_value_today FROM h305_ca77_entries ORDER BY submitdate DESC, id DESC LIMIT 1 "; $row = $pdo->query($sql)->fetch(PDO::FETCH_ASSOC); // casing helpers (same pattern as CB / CL) $keepCaps = static function (string $w): bool { return (bool)preg_match('/[A-Z]{2,}/', $w) || (bool)preg_match('/\d/', $w); }; $word = static function (?string $w) use ($keepCaps): string { if ($w === null || $w === '') return ''; if (strpos($w, '-') !== false) { $parts = explode('-', $w); foreach ($parts as &$x) { $x = $keepCaps($x) ? $x : ucfirst(strtolower($x)); } return implode('-', $parts); } if ($keepCaps($w)) return $w; $dot = substr($w, -1) === '.'; $base = $dot ? substr($w, 0, -1) : $w; $done = ucfirst(strtolower($base)); return $dot ? ($done . '.') : $done; }; $title = static function (?string $s) use ($word): string { if ($s === null) return ''; $s = trim($s); if ($s === '') return ''; $t = preg_split('/\s+/', $s) ?: []; foreach ($t as &$x) $x = $word($x); return trim(implode(' ', $t), ", "); }; if (!$row) { $line = 'Latest Registry Entry: No completed entries found.'; } else { // location like "WA, Australia" $region = $title($row['ADM_StateOrProvince'] ?? ''); $country = $title($row['ADM_Country'] ?? ''); $loc = trim( implode(', ', array_filter([$region, $country], fn($v) => $v !== '')), ', ' ); // normalize opinion_value_today using the same rules as CL: // - >=1000 => use as-is ($12500 => $12,500) // - 100..999 => treat as dollars ($750 => $750) // - 1..99 => treat as thousands (6 => $6,000) // - otherwise => "Not Entered" $valFinal = 'Not Entered'; if (isset($row['opinion_value_today']) && $row['opinion_value_today'] !== '') { $n = (float)$row['opinion_value_today']; if ($n >= 1000) { $valFinal = '$' . number_format($n, 0); } elseif ($n >= 100) { $valFinal = '$' . number_format($n, 0); } elseif ($n > 0) { $valFinal = '$' . number_format($n * 1000, 0); } } // condition code translation — same dictionary as CL plus "Rat" $condRaw = $row['condition_value'] ?? ''; $condMap = [ 'E' => 'Excellent', 'Exc' => 'Excellent', 'G' => 'Good', 'Goo' => 'Good', 'F' => 'Fair', 'P' => 'Poor', 'Par' => 'Parts Bike', 'R' => 'Restored', 'Res' => 'Restored', 'Rat' => 'Rat', ]; $condNice = $condMap[$condRaw] ?? ($condRaw !== '' ? $condRaw : 'Not Entered'); $line = 'Latest Registry Entry: ' . ($row['model_year'] ?? '') . ' Honda ' . ($row['model'] ?? '') . ' — ' . $loc . ' — Condition: ' . $condNice . ' — Value: ' . $valFinal; } // stamp + UTF-8 $built = (new DateTime('now'))->format('Y-m-d H:i:s T'); $stamp = ""; $charset = ''; $html = $charset . "\n" . $stamp . "\n" . $line . "\n"; // write to shared include $jobDir = __DIR__; $includeDir = '/home/mstoic3/public_html/shared/include'; $includeTmp = $includeDir . '/latest_ca77.tmp'; $includeDst = $includeDir . '/latest_ca77.html'; $jsonPath = $jobDir . '/latest_ca77.json'; $logPath = $jobDir . '/logs/latest_ca77.log'; // future optional if (!is_dir($includeDir)) { if (!mkdir($includeDir, 0755, true) && !is_dir($includeDir)) { throw new RuntimeException("Failed to create include dir: $includeDir"); } } if (file_put_contents($includeTmp, $html, LOCK_EX) === false) { throw new RuntimeException('Failed to write temp include file'); } if (!rename($includeTmp, $includeDst)) { @unlink($includeTmp); throw new RuntimeException('Failed to move include into place'); } @file_put_contents($jsonPath, json_encode([ 'line' => $line, 'stamp' => $built, 'ts' => date('c'), ], JSON_UNESCAPED_UNICODE)); echo "OK\n"; } catch (Throwable $e) { error_log("[generate_latest_ca77.php] " . $e->getMessage()); if (function_exists('http_response_code')) { @http_response_code(500); } echo "ERROR\n"; exit(1); }
I had a set of the JC Whitney Dunstall style pipes on a CB77, one of the 'sold' bikes on this website and I thought the chrome was great. They have a very nice bark too.Dogsbd wrote:dppeter, about those JC Whitney mufflers are those the "Dunstall" style? How is the chrome quality?
Thanks.
Yes, part number is: ZX014804P. I like them. The chrome seems pretty sturdy. Since they are brand new, I can't say how long they will last but they do look pretty good now. They hang a little lower than the originals but were very easy to mount. I did alter their brackets slightly but they really went on very easily.Dogsbd wrote:dppeter, about those JC Whitney mufflers are those the "Dunstall" style? How is the chrome quality?
Thanks.
