P.S. The spring inside isn't "loaded" or anything is it? Something to watch out for when disassembling like a valve spring.
Wilf wrote:Once the chrome fork seal housing has been unthreaded from the lower fork case (use a strap wrench or other suitable tool), the lower case should separate from the upper, thus exposing the spring and other innards. From my photo you may be able to see that removing the 3 spring clips will allow you to slide the piston, damper valve and fork tube guide off from the fork tube. You can then slide the chrome fork seal housing down and off the tube.
