Another CB77 sees daylight after 42 yrs
sixtiescycle
Post by sixtiescycle » Mon Jan 27, 2014 3:56 pm
Bottom end is together, now it's back apart. The trans I put in was pristine, everything looked great. The only thing I forgot to check were the clutch and sprocket splines. This is a late shallow spline trans and mine was the early deep spline. All swapped out again and going back together for the second time..........................
Dick Johnson
'61 CB92
'63 domestic CL72 Type 2
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
sixtiescycle
Post by sixtiescycle » Mon Mar 03, 2014 3:45 pm
I've corrected the transmission problems and dropped the engine in the frame 2 weeks ago. Today I put the carbs and point plate on, filled the float bowls and lit it off on the second kick. Some smoke, no leaks but It was only running for maybe a couple minutes. Shifts through all the gears. Sounds much better now! Now I just have to finish the installation and take it for ride.
Dick Johnson
'61 CB92
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
Post by e3steve » Tue Mar 04, 2014 6:01 pm
Seems like you're getting there. Good luck on the road test!
sixtiescycle
Post by sixtiescycle » Wed Mar 05, 2014 3:46 am
e3steve wrote:Seems like you're getting there. Good luck on the road test!
Thanks! After last years CL72 project that Murphy's law invaded it's nice to have one go fairly smooth for sure.
I put the tank on today, fueled and lit it off again running for several minutes now, smoking ceased and it idled very nicely. Valves were adjusted on the bench but the timing needs to be done. The topend is surprising quiet and so far no leaks.
Dick Johnson
'61 CB92
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
hillhudson
Post by hillhudson » Wed Mar 05, 2014 11:39 am
Come grab my timing gun! Its a crap load easier than using a little timing bulb. And much more exact.
-hill
'65 s90
'64 ca95 dream
'65 cb160
'66 cb77
Tim Miller
Post by Tim Miller » Wed Mar 05, 2014 12:59 pm
AMEN.
Tim
hillhudson wrote:Come grab my timing gun! Its a crap load easier than using a little timing bulb. And much more exact.
-hill
sixtiescycle
Post by sixtiescycle » Wed Mar 05, 2014 1:56 pm
-hill
Thanks Hill, I have one here, just need to do it! Agreed you can get the two cylinders firing exactly at the "F" marks with the timing light. There are lots of loose ends to tie up on this bike and this is just one of them.
Dick Johnson
'61 CB92
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
