While reassembling original front drive sprocket and retaining plate, I found that the sprocket was not completely tight (some side play on shaft) after tightening the two screws. Should it have any play and, if not, any thoughts on why this might be happening. Original parts do not appear to any significant wear. Am I missing any pieces?
Scott
front drive sprocket too loose?
Re: front drive sprocket too loose?It is as HONDA designed. ........lm
