lower rear shock bolt measurement. cb77
jimpapa
Post by jimpapa » Mon Aug 25, 2014 8:51 am
talking about the bottom bolt for the rear shocks
parts list doesn't specify size.
i think its suppose to install from the inside outwards
and the head of the bolt is suppose to be thinner than other bolts.
of course as i get near to putting everything back together i cant seem to find the correct bolts.
if someone knows the correct type and size it would be appreciated
thanks
In the parts guide under rear cushion it appears to be #90107-268-000
and on the rear fender page it might be #92000-0608
PhilD
Rear shock mounting bolts
Post by PhilD » Mon Oct 13, 2014 2:27 pm
Hi, you are correct that these are a special size and inserted with the head on the inside. The bolts are M10 1.25 pitch 17mm heads 4mm thick and 38mm long.
PhilD
PhilD
Post by PhilD » Mon Oct 13, 2014 2:28 pm
PhilD
Post by G-Man » Tue Oct 21, 2014 11:23 am
