Post
								by tore » Mon Nov 04, 2024 10:45 am
			All splines has lose gears. None of the gears has any friction fit to the splines. Since the gears are move somewhat freely there will be wear on the splines over time.
For example the primary gear on the crank shaft is held in place by a spring washer to keep it moving to the sides. The clutch basket is free moving. The chain keeps the clutch basket lined up. Brilliant design if you want something to run smooth but less good for long time wear.
