When you set the cam chain with the camshaft set at the punch mark, that looks like a 0 stamped into it with the pointers lined up to T on the stator. Is that the location when you set the valves or is it a rotation past that on the stator markings?
In other words in the camshaft punch mark and the stator T mark lined up at the ignition stroke and then 360 stator rotation past that the exhaust mark?
Thank you
Cam Chain timing questing
SUperhawk_Clark
Re: Cam Chain timing questing
Turn rotor 360 degrees (line on end of points cam is now down) and set right side.
Turn 180 degrees and set left side. ..........lm
SUperhawk_Clark wrote:When you set the cam chain with the camshaft set at the punch mark, that looks like a 0 stamped into it with the pointers lined up to T on the stator. Is that the location when you set the valves or is it a rotation past that on the stator markings?
Thank you
