Do the headlights go on if you position the switch to headlight position
(4th position) without the engine running on a 250 ca 72 ?
do headlights go on without motor running
johnjoseph1
rzgkane
Re: do headlights go on without motor running
Yes. Power to the headlights is sent when switch is in the headlight position.johnjoseph1 wrote:Do the headlights go on if you position the switch to headlight position
johnjoseph1
Thank you so much huntington beach. I appreciate it ...johnjoseph1 wrote:Do the headlights go on if you position the switch to headlight position
