ignition switch
danielmoto
ignition switch
Post by danielmoto » Mon Jan 02, 2012 5:57 am
could i have advice on the removal of the ignition switch/barrel removal from the frame, looks like it has a ring that maybe screws off, thought i better ask as it looks like its been removed in the past via a screw driver and hammer combo and as it works fine i dont wont to damage it. (appologies if this is a dumb question as ive tried searching but found no answers and i believe its better to ask and look a prat than to not ask and damage something cheers danielmoto. Its on a cb72 .
danielmoto
Post by danielmoto » Mon Jan 02, 2012 8:42 am
me again, thought i would leave the request for information on how to remove the ignition switch/barrel as reading it again after unscrewing the above mentioned from the frame i couldnt stop laughing im only 42 and im loosing me marbles already.
MBellRacing
Post by MBellRacing » Mon Jan 02, 2012 4:06 pm
I think I get what you're asking. My CB77 was the same way-- it doesn't want to come out sometimes in the painted frame. The ring on the front unscrews from the barrel and the barrel itself pulls out from the frame straight. DO NOT TWIST IT. There is a little alignment tooth that stops it from rotating when the key is turned. Find a way to tap it out from the rear. Take care, though, it has an epoxy/plastic back side.
danielmoto
Post by danielmoto » Mon Jan 02, 2012 4:40 pm
many thanks for reply stripped the whole bike and i got stuck on the ignition switch/barrel, it just would not budge its out and sorted now cheers .
