correct Tappet clearance for 65 CA77 dream
roadrunner
Post by roadrunner » Fri Sep 18, 2015 4:37 pm
ha guys i need the correct clearance adjustment for 65 CA77.i have a service manual on order not here yet thxs for the info.
Re: correct Tappet clearance for 65 CA77 dream
Post by LOUD MOUSE » Fri Sep 18, 2015 6:21 pm
ALL-----------.004. .....................lm
roadrunner wrote:ha guys i need the correct clearance adjustment for 65 CA77.i have a service manual on order not here yet thxs for the info.
roadrunner
Post by roadrunner » Fri Sep 18, 2015 7:13 pm
thank you LOUD MOUSE thats great.i'm going to adjust the points & timing the way you explaned it the motor doesn't smoke sooo after i set it up like you do she should run like a raped ape.
roadrunner
Post by roadrunner » Fri Sep 18, 2015 7:18 pm
LOUD MOUSE that is .004mm ?
Post by LOUD MOUSE » Fri Sep 18, 2015 7:26 pm
MM doesn't count that way.
.004 TH. .....................lm
roadrunner wrote:LOUD MOUSE that is .004mm ?
roadrunner
Post by roadrunner » Fri Sep 18, 2015 7:29 pm
i learned something new everyday that makes it a great thxs.
