CA78 ignition wire replacement
garncarz
Post by garncarz » Wed Dec 04, 2013 1:42 pm
Is there a practical way to replace dry rotted ignition wire and still keep the original coil? If not, does anyone know the electrical specs on the OEM coil. Thanks!
cadman
Post by cadman » Wed Dec 04, 2013 7:49 pm
Basically a coil is a coil is a coil. Mine ran with a automotive coil and the plug wires spliced together. Look for an early 350-500-750 coil. I used one from a 500/550 - wires are about the right length and it will fit in the frame.
garncarz
Post by garncarz » Thu Dec 05, 2013 9:00 am
Are original Honda wires solid (copper, SS, etc.) core or carbon core? Resistor or not? Thanks.
Post by LOUD MOUSE » Thu Dec 05, 2013 10:49 am
Solid wire. .........lm
garncarz wrote:Are original Honda wires solid (copper, SS, etc.) core or carbon core? Resistor or not? Thanks.
garncarz
Post by garncarz » Wed Dec 18, 2013 2:59 pm
I bought new 7 mm copper core wire and non-resistor plug caps and spliced them in at the coil. Works like a charm. The ignition system puts out EMI bigger than a tactical nuke, but that's part of the charm.
