Ca77 advance springs source
Tinman
Post by Tinman » Fri Aug 23, 2013 1:30 pm
Does anybody know of a source for the ca77 advance springs (14329-259-310)? eBay has them for $40 for the pair, but that's a bit high. Or, can you substitute the cb/cl springs that are available?
Thx,
Tinman
Jims65CA77
Post by Jims65CA77 » Sat Aug 24, 2013 11:15 am
They look like they are different after all, as they have different part numbers.
The CB77 - 14329-268-320
Jim
Tinman
Post by Tinman » Sat Aug 24, 2013 12:28 pm
I realize the others are for the CB/CL and the spring tension is probably a bit stiffer and the length maybe be different as well. I just don't know if they're a good substitute. I maybe S.O.L., but I was waiting for one of the Guru's to chime in and shed some light. Thx for the info.
Tinman
Jims65CA77
Post by Jims65CA77 » Sat Aug 24, 2013 1:32 pm
Yeah, I am new to the 305s and I just wanted to make sure you knew that the part numbers were different. I also found out the CL305 is different than the CB!
CL305 - 14321-268-020
Hopefully a true GURU will know.... ;^)
Good Luck!
Jim
Post by LOUD MOUSE » Sun Aug 25, 2013 2:15 am
The DREAM spring is a touch longer than the CB/CL which are the same. ................lm
Jims65CA77 wrote:Yeah, I am new to the 305s and I just wanted to make sure you knew that the part numbers were different. I also found out the CL305 is different than the CB!
Good Luck!
Jims65CA77
Post by Jims65CA77 » Sun Aug 25, 2013 7:29 am
LOUD MOUSE wrote:The DREAM spring is a touch longer than the CB/CL which are the same. ................lm
Good Luck!
Not sure why, but the parts books for the CL and CB had listed them with different numbers. I suppose they could be "superseded" or something like that? Glad you cleared that up LM!
Jim
