No power to the plugs
Tinman
Post by Tinman » Mon Oct 01, 2012 10:40 pm
Points have spark, but no power at the plugs. Bad coil?
Tango911
Post by Tango911 » Tue Oct 02, 2012 8:00 am
if there is power to the points and not to the plugs. its either bad coil or bad plugs. dont assume that both plugs cant be bad. Check the plugs first. also there could be a connection to the coils thats not making contact.
Tinman
Post by Tinman » Tue Oct 02, 2012 8:21 am
Thanks Tango. I can get my hands on a plug tester, but do you know of a way to check a coil?
48lesco
Post by 48lesco » Tue Oct 02, 2012 9:53 am
??? Points shouldn't spark. I'd check to make sure the condenser is hooked up properly and grounded. Trim a little off the ends of your plug wires and redo the caps. Check for spark by holding the plug against the head preferably not too near the spark plug hole. You can get a combustible mixture coming out of there and well... Or, just plug the hole with another spark plug. Always wear eye protection.
-48
Tango911
Post by Tango911 » Tue Oct 02, 2012 3:30 pm
+1 for the above post
65 Sears Puch 250
69 Dream 305
74 Kawi H1
78 CB750 SS
Snakeoil
Post by Snakeoil » Tue Oct 02, 2012 4:38 pm
48lesco wrote:??? Points shouldn't spark. I'd check to make sure the condenser is hooked up properly and grounded. Trim a little off the ends of your plug wires and redo the caps. Check for spark by holding the plug against the head preferably not too near the spark plug hole. You can get a combustible mixture coming out of there and well... Or, just plug the hole with another spark plug. Always wear eye protection.
-48
Yup, gotta agree. Points sparking indicates bad condenser and no spark at the plugs with power at the points pretty much confirms it. If you have a pair of old condensors sitting around, wire them in and see if you now get spark at the plugs.
regards,
Rob
