fouling plugs so fast!?
Sascha
Post by Sascha » Fri May 20, 2011 7:44 am
Hey Guys,
So yesterday I took her for a run and she ran SUPER strong for about 30 minutes then died on me... I pulled the plugs and they are fouled, it happened twice; wondering if anyone can tell me why this would be? I took a picture to demonstrate the issue...
Thoughts on if I need to adjust the air screw maybe? Would having it too tight cause this?
Here is a link to the picture of the plug (on my blog): http://thepersian.com/?p=460
-Sascha
Atlas
Post by Atlas » Fri Jul 29, 2011 3:56 am
Hi, What # and brand are you running and what size is your low speed jet in the carb also you might try to lower the needle in the slide down a notch. Atlas
Post by LOUD MOUSE » Fri Jul 29, 2011 9:37 am
Ya replied to a message posted May 20. ................lm
Atlas wrote:Hi, What # and brand are you running and what size is your low speed jet in the carb also you might try to lower the needle in the slide down a notch. Atlas
Atlas
Post by Atlas » Wed Aug 10, 2011 9:26 am
Hello LM, Are you trying to be rude. Sometimes a problem doesn't get fixed for months but i'm new to this forum so mabe there's a time limit on replying to posts? Atlas
Post by LOUD MOUSE » Wed Aug 10, 2011 10:18 am
Take it for what it is.
He hasn't posted to the forum since June 7 and has had the problem solved before that. ..........lm
Atlas wrote:Hello LM, Are you trying to be rude. Sometimes a problem doesn't get fixed for months but i'm new to this forum so mabe there's a time limit on replying to posts? Atlas
Atlas
Post by Atlas » Wed Aug 10, 2011 4:31 pm
Sorry LM I had no way of knowing without them replying to something. As you said take it for what it is. Just lighten up a little. Sorry if i offended.
Post by LOUD MOUSE » Wed Aug 10, 2011 8:23 pm
Ya didn't/don't offend me.
It was a clue for ya to look at and consider if ya have new or current info to offer to the subject which had ended a long time before ya offered the same info which was offered to the same member on a separate heading addressing the same problem and the problem had been cured a long time back.
Lighten up!!!!!!!!!!!!! Ya!!!!!!!!. ...........lm
Atlas wrote:Sorry LM I had no way of knowing without them replying to something. As you said take it for what it is. Just lighten up a little. Sorry if i offended.
