Howdy,
CB77E seems to not run/fire good on the right cylinder.
right points are arcing even though it's been filed and cleaned.
Right side coil gets warm to the touch, other side does not.
Tried changing condensors and plugs to no avail?
Comments please...
Thanks
Warm coil and points arcing
roadcapDen
- Contact:
roadcapDen
2 HD XL's
65 Dream 305
and a bunch of other scoots
2 HD XL's
65 Dream 305
roadcapDen
- Contact:
Den,
Did you replace the condenser with a new unit? Is everything grounded properly? You have the ground strap that goes from top engine mount bolt to coil mount? Cleaned and sanded paint from frame where ground attaches? It is normal for the coils to get warm, strange that it's only the right one though.
Davo
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
