Hey Guys,
So I have a few problems with starting the bike - ive talked to a few of ya! ;)
Given my new wiring, I am wondering how I can go about priming the bike without a "position 2" on the key? Can I wire to accomodate this?
-Sascha
Question about primingShouldn't need to prime unless it has been a while since the bike has been started.
If so, you can pull choke lever up and kick it over with the ignition off a couple of times before you try to start it with fire. How cold is it there? Mine is very cold-blooded and will not start without full choke and no throttle. What has changed since you last had it running?......motor rebuilt, points changed, carb disassembled, valves or timing adjusted ...etc? 66 dream, 78 cb750k, 02fz1, 09 wing
