Spark plug cap rebuildability
Eljeef
Post by Eljeef » Sun Aug 02, 2009 2:16 pm
Hi. Has anyone tried to rebuild the original grey metal spark plug caps on the early Dreams? Can someone tell me what ohm diode is in it? I am not sure how to get the cap apart without ruining it but I would rather have the original caps than the current black replacements. Regards, Jeff.
Re: Spark plug cap rebuildability
Post by LOUD MOUSE » Sun Aug 02, 2009 5:21 pm
Tis been a while but I think a flat/wide blade screwdriver can/will remove the part which contacts the top of the plug.
I've found a couple (not many) which were loose and when I turned them in the cap worked again. ..........lm
Eljeef wrote:Hi. Has anyone tried to rebuild the original grey metal spark plug caps on the early Dreams? Can someone tell me what ohm diode is in it? I am not sure how to get the cap apart without ruining it but I would rather have the original caps than the current black replacements. Regards, Jeff.
Post by davomoto » Sun Aug 02, 2009 6:16 pm
Like Ed said, a good size flat blade screwdriver should remove the end that goes to plug. I then bead blast inside both ends, clean with brake parts cleaner, and use dilectric grease on threads when re-assembling.
Eljeef
Post by Eljeef » Mon Aug 03, 2009 6:38 pm
LOUD MOUSE wrote:Tis been a while but I think a flat/wide blade screwdriver can/will remove the part which contacts the top of the plug.
Thanks LM, thanks Dave. I checked that screw out, took it out and cleaned all brass contacts. It still doesn't work. I think the diode inside must be shot. I seem to recall somewhere on this forum somebody mentioning that they had 1ohm resistors in them. Would a five ohm cap be o.k. to use? JH.
