No power to the points
bj
Post by bj » Tue Sep 30, 2008 10:29 pm
I wasn't getting a spark so I swapped out my points with some brand spanking new ones. Put in a new condersor also. Now when there is no power to them. When check with the ammeter.....nothing.
What do you guys think?
Thanks,
Bryan
Re: No power to the points
Post by LOUD MOUSE » Wed Oct 01, 2008 12:54 am
Look at the screw where you put the condenser wire. Remove it and then check for 12 volts then attach it to the points so you still have 12 volts. If not attached to the screw correctly it will put the 12 volts to ground. ..................lm
bj wrote:I wasn't getting a spark so I swapped out my points with some brand spanking new ones. Put in a new condersor also. Now when there is no power to them. When check with the ammeter.....nothing.
Thanks,
Bryan
RIDE IT DON'T HIDE IT!
bj
Post by bj » Wed Oct 01, 2008 10:15 am
Thanks,
I'll give that a try tomorrow.
Bryan
kustommusic
Post by kustommusic » Wed Oct 01, 2008 4:37 pm
BJ, OR if the points were closed at the time you metered them it would read no voltage. Kustommusic
bj
Post by bj » Thu Oct 02, 2008 2:45 pm
Thanks Guys
That was it. It was grounding out. I took it down the road and it ran better than ever. It even started with one plug out.
Bryan
P.S
Don't ever work on the points with the spark plugs out. I thought I dropped on of those tiny washers from the points screw down in the hole. Just about had a heart attack. Luckily, I found it sitting in the middle of the cooling fins.
cac
Post by cac » Sun Sep 20, 2009 8:25 pm
bj wrote:Thanks Guys
Bryan
P.S
Ya I did that and still dont know if I lost a washer .
I'm hooked on the resto project!!!!
