Which Spark Plug Cap?
Erich
Post by Erich » Thu Sep 25, 2008 1:27 am
I was wondering which spark plug caps to get for my CA77.
Saw a pair on ebay......looks like NGK P/N LB05F
Here's the NGK pdf...... http://www.ngksparkplugs.com/docs/Resistor_Covers.pdf
Both my dreams could use some fresh caps. I searched and couldn't find any posts on the topic.
Thanks
Erich
brewsky
Post by brewsky » Mon Jun 07, 2010 6:44 pm
BUMP!
Same question. Need new caps for the dream, with stock coil, wires, and non-resistor plugs?
What resistance caps....0, 5, 7.5, 10, or?
Thanks.
gramey7
Post by gramey7 » Tue Jun 08, 2010 9:12 am
Not that this is the definitive answer, but when I ordered caps from Nick at Ohio Cycle a few years ago for my CL77, he sent the LB05F caps, 5K ohms .
eyhonda
Post by eyhonda » Tue Jun 08, 2010 1:09 pm
I believe 5k ohms are normal standard values that will work fine. I have same on my cb77.
63 cb77 cafe
www.eyhonda.com
brewsky
Post by brewsky » Wed Jun 09, 2010 5:57 am
Thanks for the replies...I couldn't read the numbers on my caps and not sure they were correct anyway.
brewsky
Post by brewsky » Wed Jun 16, 2010 6:55 pm
Ended up with NGK LD05F from my local dealer. $2.80 each
NGK site shows the LB05F is for 14mm plugs, and LD05F is for 10 and 12mm.
