points
jensen
Post by jensen » Fri Dec 17, 2010 8:59 am
Swap the condensor,
jensen
Post by LOUD MOUSE » Fri Dec 17, 2010 9:05 am
Ya have been working in that area so I recommend ya clean the points.
I use folded 600 grit Wet or dry (black) sand paper (dry) and with the points closed I draw the paper through the points a couple of times.
If ya have contact cleaner ya can open the points and spray them.
I then draw a business card through them when they are closed to finish the job. .............lm
Sascha wrote:Hey guys,
So with the help of LM i got the points and timing corrected (0.014" gap at highest and opening @ F on rotor).
I am getting a spark between my points, is that a bad thing or a good thing?
Do I need to do something to my condensor?
-Sascha
bonjour wrote:Clean the points, if the sparks still occur, replace the condensers.
Also be sure that all contacts in the ignition circuit are clear, give good attention to the coils/ground there.
Probably is wise to do that also after you cleaned the points.
anyway, sparks generally only occur when the condensors are worn/don't function.
'officially' you should replace the points and condensors at the same time.
I always like shiny new ignition parts, the whole lot, and I generally always change/renew it when I get problems or 'issue's' with it, or don't trust stuff.
Anyway again, sparks between the points generally only occur when the condensors are worn/don't function.
Sascha
Post by Sascha » Fri Dec 17, 2010 9:19 am
I have a brand new condensor on there already... Just put it on... took sand paper to the contact points as well.
-Sascha
jensen wrote:Hi,
Swap the condensor,
jensen
Post by LOUD MOUSE » Fri Dec 17, 2010 9:32 am
Did ya tatally clean them the way I described?. .......................lm
Sascha wrote:I have a brand new condensor on there already... Just put it on... took sand paper to the contact points as well.
-Sascha
jensen wrote:Hi,
Swap the condensor,
jensen
Sascha
Post by Sascha » Fri Dec 17, 2010 10:14 am
I used 600 grit - no spray cleaner.
-Sascha
jensen
Post by jensen » Fri Dec 17, 2010 10:15 am
NEW or NOS condenser ?
and clean the points as Ed says, use break cleaner if necessarily,
Sascha
Post by Sascha » Fri Dec 17, 2010 10:32 am
NOS condensor - looks identical to the old one, just new.
I will try to brake fluid - should cleaning it stop it from sparking?!
-Sascha
