advance unit springs
jerry
Ignition mechanical and electronic
Post by jerry » Thu Feb 18, 2010 7:19 pm
Dear All, This neoprene issue got me curious and Good on You Loudmouse I learned some more about the Early Hondas. Every cam sprocket assy.we have here (checked 8 of them) has those neoprene buffers on the bobweight pins. The thickness is approx 1.8mm. Something new everyday even for us old ones. Jerry
Re: Ignition mechanical and electronic
Post by LOUD MOUSE » Thu Feb 18, 2010 11:06 pm
I found them in the early 60's the hard way when I (in my ignorance) soaked that assy. in carb cleaner and found 2 black/neoprene things floating in the cleaner.
Did take a moment to find where they came from but as ya can imagine when I lifted the weights and released them I heard a CLINK which I had never heard which caused me to look at the area of another part.
Ya can bet that part never sees carb cleaner now. ..........lm
jerry wrote:Dear All, This neoprene issue got me curious and Good on You Loudmouse I learned some more about the Early Hondas. Every cam sprocket assy.we have here (checked 8 of them) has those neoprene buffers on the bobweight pins. The thickness is approx 1.8mm. Something new everyday even for us old ones. Jerry
48lesco
Post by 48lesco » Wed Mar 10, 2010 1:24 pm
If its neoprene, can we clean off the old stuff and heat-shrink some new stuff on? Neoprene heat shrink comes in various wall thicknesses and even with adhesive inside that sticks pretty good. If there was a groove in the pin it would stay stuck even better... Wouldn't want to take a chance of it coming off and plugging an oil gallery, but I guess Honda did. I'll try to determine the right dia and wall thickness to get us back near new and see if I can find some. Anybody have one without any rubber that can see if there's a groove or reduction in diameter at the base that would keep the neoprene from slipping off?
Bob750
Post by Bob750 » Fri Mar 08, 2013 12:10 pm
Good threads never die!
But some of them come to an abrupt stop.
Had: '75 CB550 K, '79 CT90
