OK. New points, condensor, wires. I have spark on the right side. If I switch the green wire to the left coil I get spark. Power to both coils is there.
Battery is down a bit from testing for spark with the electric start but I get 10.95 Volts at the green points and 00 at yellow.
Bad condensor?
no spark left side
no spark left side
should I see voltage at the yellow end of the condensor with the key on? I have none. It was a NOS unit.
no spark left side
I got a new condenser from Classic Honda Restoration and now have spark on both sides.
Thanks for the input.
