Neutral light
GregMcN
Neutral light
Post by GregMcN » Thu Jan 18, 2018 3:33 pm
Does anyone have a picture of the neutral light (electrical side), I have the lens and plastic nut fitting but nothing else.
Thanks Greg
win1906
Post by win1906 » Sat Jan 20, 2018 8:51 pm
just a bulb with the rubber.green and red wire and black for ground
rrietman
Post by rrietman » Sun Jan 21, 2018 1:21 am
there is a rubber boot that fits over the lip of the plastic nut. a two wire bulb assembly simply pushes into that boot. Tim at vintagehondarestorations sells the whole thing. I think Kevin at scramblercycles also does. DavidSilverspares also has the whole thing listed.
Good luck
Randy
DJM
Neutral light wiring.
Post by DJM » Sun Jan 21, 2018 12:38 pm
The black wire ISN'T the ground but is a live or HOT feed.
The bulb is Live or HOT all the time and lights up when the green/red wire is grounded or earthed via the neutral switch, only when the bike is in neutral obviously. Simple system which works well enough and is usually trouble free.
GregMcN
Post by GregMcN » Thu Jan 25, 2018 12:09 pm
Thanks all for the information ( and apologies I meant to post under electrical). I could not find a David Silver item but will check the others though maybe I could also find something generic now I have a better idea.
Greg
AlanW
Post by AlanW » Thu Jan 25, 2018 6:18 pm
Greg, Look on ebay number 232539842224 and you will see one with the parts for sale.
Al.
GregMcN
Post by GregMcN » Fri Jan 26, 2018 1:57 am
Thanks Alan, if I am looking at the right thing then the light is at right angles to the lens in the shell?
