Ed moore's tuning recipe...
carlluvscorinne
Hi all: I have a 1964 CB77 and my question is, After using ed moore's tuning recipe, am I not to be concerned with what the timing looks like with a timing light? It seems as though if you follow ed's instructions, I don't need to even use a timing light at all..Is this correct? Thanx in advance, Carl
I would like to stress an addendum to Ed's technique. Redo the procedure after about 60 miles or so. The cam riders on the points need to break in. I learned the hard way, after several hundred miles I started getting advanced a bit too far and predetonation at top speed caused me to burn a hole in my right piston!
I am now rebuilding the engine and will install the electronic ignition and never worry about it again!
