no spark
litebulblsc
no spark
Post by litebulblsc » Sun Jun 10, 2007 4:05 pm
if you have no spark, wheres the best place to start looking
Post by 305 » Sun Jun 10, 2007 5:30 pm
i'd start at the points..and see if they are not cruded up/burnt/worn out. make sure they are opening and closing proberly.check for proper gap. then check to see if you are getting power to the points. check all the wires ...there may be a crack
you may also want to try another spark plug , it may be bad
is the battery fully charged?
if this doesn't do it , it could be a bad coil or spark plug wire.....or even a shorted condensor , kinda unlikely but possible
what bike?
litebulblsc
Post by litebulblsc » Sun Jun 10, 2007 8:07 pm
http://www.honda305.com/forums/viewtopic.php?t=1703
that one
where are the points located, not use to working on motorcycles
Post by 305 » Sun Jun 10, 2007 9:39 pm
right side of the engine , on the head above the spark plug there is a cover held on by two screws..under that
