Positive and negative post on coils
CFL
Post by CFL » Mon Oct 15, 2012 8:23 pm
I cannot determine from the wiring diagram which wires go on the coils. Do the yellow and green wires, from the points, go on the positive or negative posts of the coils.? The diagram shows a black wire from the ignition switch goes to the coils and splits to each, but which side? Many thanks, CFL
Tinman
Post by Tinman » Mon Oct 15, 2012 11:04 pm
CFL, I believe that the black wire will be your positive side. Get your multi tester on there and see if you have 12v, if not try your yellow lead.
Tinman
Tinman
Tinman
48lesco
Post by 48lesco » Tue Oct 16, 2012 8:32 am
Yes, black to positive terminals on the coils. Yellow (left) and Green (right) to condenser, then to points. Make sure the condenser is well grounded by its ground strap.
raindriver
Post by raindriver » Fri Oct 19, 2012 6:36 pm
Thanks for asking that question, CFL, and thanks Tin and 48 for answers.
I have the 'official' wiring diagram - full-size and in colour! - but it does not show which side of the small coil connections the black and green (on my Dream) go to. Now I know how to tell properly, rather than just going with 'well this way works', thanks!
48lesco
Post by 48lesco » Fri Oct 19, 2012 10:04 pm
RD - Info above is for a CB77 with two separate coils. For your Dream, green goes to points and condenser, black to ignition 12V.
-48
