Left side not firing... I'm out of ideas...
SUperhawk_Clark
Post by SUperhawk_Clark » Thu Jul 19, 2012 5:11 pm
I am hoping you guys will have a bit of advice for me:
Exhaust: cold/cool compared to the right side
I can pull the left spark plug boot off and bike still runs, no change in engine sound. Pulling the right side kills the engine, thus running on only the right side.
Points are new, same volt reading at both points; ground at engine, positive at wire leading to coil.
Left side spark plug black with soot.
Plug wires clipped/shortened with new boots. Spark at left boot/plug when placed on engine block.
I have flipped the coils and left side still does not fire
New pistons and rings, valves set to proper clearance, points set to proper spacing, points plate set in correct position, using 12v light.
Carbs rebuilt, float bowls set to correct height.
All settings using Ed's tune up guide and using Mr. Honda's info as reference.
mike in idaho
Post by mike in idaho » Thu Jul 19, 2012 8:25 pm
New plugs?
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
SUperhawk_Clark
Post by SUperhawk_Clark » Thu Jul 19, 2012 9:32 pm
Yes, new plugs are being used...
Someone suggested the condenser being bad, any thoughts?
Hahnda
Post by Hahnda » Thu Jul 19, 2012 11:34 pm
Have you pulled the bowls to make sure they have fuel in them? Petcock flowing freely?
teazer
Post by teazer » Fri Jul 20, 2012 12:19 am
If that plug really is new, how do we explain the fact that it's all black and sooty? Soot indicates it is burning very rich and fouling the plug.
Replace that plug or swap them over and wee if it still runs on one side.
Then check the carb on the dead side for low floats (flooding) poor needle and seat sealing, missing pilot jet etc.
SUperhawk_Clark
Post by SUperhawk_Clark » Fri Jul 20, 2012 6:54 am
I rebuilt the petcock and I am running clear fuel line and can see fuel flowing.
That is a very good point about the plug... Is it possible the side is firing at higher rpm's?
One thing I did have to do to the points plate was grind the rotational adjustment holes so that I could turn the plate far enough to line up the 12v light lighting.
I will be working on it today, I will double check the advice given.
Thank you
Clark
Post by davomoto » Fri Jul 20, 2012 11:38 am
Timing chain may be off one tooth, you shouldn't have to grind anything to set timing. have you checked compression?
Davo
