Slo, there are 2 gaskets, one above the strainer, and one below. Make sure you have both gaskets before proceeding, or else just re-assemble. You'll probably have to pry under the gasket , I use a single edge razor blade, and go around until you can remove strainer. Hope that helps!
Different Exhaust Patterns
Davamoto,
thanks on the oil strainer tip.
But back to the carb issue, I am (once again) confused. Several other posts I have read say that turning the air screw(fuel screw?) OUT makes the mixture LEANER. Could it be that different models have different carbs? My bike is a single-carb 1967 CA77.
-Slo
-Slo
