Gents,
A few weeks ago My bike(66CL77) died on the way to work, I checked the timing and it was a little off. I re-adjusted the timing per Loud Mouses instructions as I have since aquiring the bike, I fired it up and it ran, but I had some popping and backfiring. I went over the timing a few times again with no improvement so I decided it would be a good time to replace the oil seals plug wires and clutch cable as I had been putting that off. I figured I would get to the timing later.
Once that was done I rechecked my timing and fired off the bike. This time I was only running on the left cylinder until I crack the throttle then I get fire to the right cylinder, at idle it's only on one cylinder. Once again I set the timing per LM's instruction, I have fuel and compression but no spark(at idle). Any ideas to what the problem might be?
No spark at idle
No spark at idle
Ron Cribbs
1966 CL77
1965 CB160
1974 Triumph T150V
1966 CL77
1965 CB160
1974 Triumph T150V
For those concerned, a dirty point(s) will cause the symptoms mentioned above. I only have less than 1000 miles on the set not sure why they became so dirty. I had to clean them a few times until they worked correctly.
As LM's instructions read "Points must be clean"
Lesson learned!
Lesson learned!
Ron Cribbs
1966 CL77
1965 CB160
1974 Triumph T150V
1966 CL77
1965 CB160
1974 Triumph T150V
